Texecom Veritas Alarm
8 Feb 2015
Warwickshire
Hi Guys
My last tennant has installed a veritas alarm, the one with the DCA 0001 led remote keypad,
im having problems setting it up for the new tennants, basically they want zone 1,2,5 & 6 working as part set
for when they go to bed at night. The issue is they can omit the zones 3 & 4 but for some reason zone 5 & 6
wont work when being part set, however zones 5 & 6 work when full set.
What am i doing wrong?
Zone 1 is the kitchen
zone 2 living room
zone 3 is hall
zone 4 is stairwell
zone 5 is frontdoor contact
zone 6 is backdoor contact
reason why zone 5 is frontdoor and 6 is backdoor is because we decided to have them fitted recently.
Hopefully someone can shed some light on this for me, its so frustrating!
thanks guys
try this
You need to set up part set suite for each part set
Option 51
This will show you what zone are on in part set
So zone 3 and 4 led need to be off in the part suite and all other zones need to be lit(red)
Now when you part set zones 3 and 4 will be off.
Neil a option will only change zone function not set up part set function
To set up a part set suite you will need the engineer code to do this
Hope this helps
Option 51
Hope this helps
Thank you so much, I will try this first thing in the morning. Tenants move in around lunchtime, cutting it kinda short.
Once again
Thank you
Option 51
Hope this helps
Thanks mate it worked, just another question please, is there any reason entry/exit is hit & miss? It don't always activate when the door is opened, possibly 1 in every 5 tries does the entry /exit start timing down.
Are 100% sure door contacts are on entry/exit and not a movement sensor?
A door contact will start entry timer when door opened
A movement sensor will start entry time when first picks up movememt as long as it is programmed for entry/exit
Hope that explains
Hit the Thanks?
Just thinking about the layout and the programming.
If you right down what you want what zones to do in full set and part set then can be more specific about the programming
