- Joined
- 28 Dec 2016
- Messages
- 115
- Reaction score
- 4
- Country
Been nosing in this forum for years but as I need advice now signed up. Bit of a long winded scenario but will try to keep it brief.
Recently moved into a 5 bed cottage with radiators on both floors. The boiler is an old oil fired job situated in an outbuilding some 20m from where the hot water pipes, 35mm, enter the property. The thing works okay but efficiency of said boiler leaves a lot to be desired. Hot water is provided by standard vented cylinder with heating and hot water tanks in loft. First thing I thought I would do is lose those and install a sealed system like I had previously when using a thermal store for the HW. We are in a very hard water area currently with a salt water softener in the system. I do not like these for various reasons. So thought out with that and in with my favoured electronic scale reducer using a thermal store as opposed to say a megaflow. As the thermal store will have the same water in from day one if treated at the outset scale is not a problem. Now though I am thinking that if I go over to a sealed system with an increased pressure in water not sure if the old heating pipes can cope with it. I cannot really replace them as the cottage is a 16c job with all the pipework hidden. So the crux of my question is can I use a thermal store with current system ie keeping tanks in the loft. The actual water pressure to the cottage is not brilliant, even though I have a massive water tower some 100m away!
Any advice gratefully received.
