- Joined
- 10 Oct 2011
- Messages
- 16,396
- Reaction score
- 4,043
- Country
Upstream being BEFORE....
That'll be downstream of ECV..Hi Terry so how do you remove a meter when you are going to solder onto the outlet of the meter if you can not work on anything before the meter outlet ?
correct steele got the lurgy not thinking straight but the job can be done easily enoughThat'll be downstream of ECV..![]()
Yes that would workG1NZO, ignoring pipework to the right, do you think there would be enough clearance if the meter was just moved downwards as far as it will go WITHOUT disconnecting the flexible stainless steel pipe?
Based on exactly what size your runners are I suspect that it might do.
Tony
i thought i was getting slower but 90 mins ??Would probably take about 90 minutes.
ThanksI think that many RGIs will consider themselves able to do that and make the required modifications to the outlet pipes.
Tony
Upstream being BEFORE....![]()
