Entertainment centre for the living room quote?
10 Feb 2016
Just wanted to ask if anyone has any idea how much a quote would be to get an entertainment centre built in my living room.
The ones I have seen online are either too big or too small and just don't quite cut it.
It would be 220cm x 40cm x 186cm.
I have posted an image to give you an idea.
Thanks!
What wood? carpenters seem to charge about £170 per day. There is probably a days work there and £100 worth of materials if pine, chipboard or ply, English Oak another £300
Thanks motorbiking, was thinking of oak veneered ply or mdf, hate chipboard, just seems to fall apart.
Maybe worth getting some quotes then, this one is £600 on wayfair, it would be pretty much perfect but it's out of stock!
Thanks again!
i'd trawl ebay and with the change buy myself a media player and flog my dvd collection.
which means you don't then need such a big unit.
Thanks for your help, may look at a low profile stand, and then shelving above and maybe to the side, hopefully if I employ a chippy to do it he will make a good job of it!
So in your most favorable scenario you think you'd get that built for £270? You're dreaming!
The OP posted an idea of what he wanted. If using sheet materials I reckon 3 maybe 4 boards (3 * 405mm x 2,400mm boards from each) - so £80-120 (MDF 18mm is £78.12 retail from my local timber place), if using finished ready furniture board, then you need another £100-150 in materials, but then you don't need a chippie to cut something that is only slightly more complex than flat pack. A lot of timber merchants have cutting services. Rather than pull out draw units, I'd probably buy a kitchen draw kit and just use a facia. You can get those for £15-20 each.
So yeah £300 is not wildly off.
No chance.
Anyway @ the OP I'd wait for your flatpack one to be back in stock unless you have deep pockets, at least you'll be able to dismantle it and take it with you.
