- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
If they were DC it wouldn't know what the voltage was.
When measuring current, they measure current, irrespective of voltage (anyway, what voltage would you be talking about - between what and what?) - so they don't care whether the circuit responsible for the current they're measuring is powered from a 1V, 12V or 10,000V source!Sorry to butt in on BANS threadWould they work on 12 volt dc then
So it seems! I did merely ask if 'they' (Hall effect meters, not specifically the T5) could work with DC!But the T5 only does AC.
The guy holding the meter might care...they don't care whether the circuit responsible for the current they're measuring is powered from a 1V, 12V or 10,000V source!
As has been said, although meters with Hall effect sensors theoretically can measure DC current, many of them (like the T5) which presumably use such sensors appear not to be designed to. I don't know whether that means that they don't work at all with DC or whether they are just not accurate enough. Maybe someone with a T5 or such like could try?Would they work on 12 volt dc then
Strange. Assuming it really was fairly clean DC, it is hard to see how a properly-functioning 'hard-wired' ammeter (particularly one of such a reputable make) could give "wildly inaccurate readings". Are you sure that it wasn't being confused by something other than DC?But even the hard wired AVO digital auto electricians meter could give some wildly inaccurate readings, it showed the two way radio was using 100 amp on transmit, with 14/0.014 cable impossible it would have melted the supply cable.
Your only option is a 'clamp' meter or one of these 'open jaw' things like the Fluke T5 (or the Extech one I've just illustrated) which (presumably) use Hall Effect sensors.So what is be best way on measuring currents besides breaking into the circuit.
Whilst some of the cheaper ones are probably OK, any of the big name ones (like Fluke) would be as good as anything. Bear in mind, though, as I've been saying, that many of them cannot measure DC current, so you have to look specifically for that capability if you want it. None of the 'clamp' meters using current-transformer technology will work with DC - and (as with the T5) even some of those which are presumably using Hall Effect technology do not claim to be able to measure DC current (without breaking into the circuit).And mostly which clamp meter make and model do you guys recommend for DC & AC which would give u an accurate reading is Fluke any good
I've never 'eard of such a thing ... I'm off to consult Mr Google!The T5 may be using a Rogowski coil (qv). This allows open ended jaws without being able to measure DC.
Note the word transmit, I am sure it was the RF causing the meter to give wrong readings, however at the time 2 way radios were common.Strange. Assuming it really was fairly clean DC, it is hard to see how a properly-functioning 'hard-wired' ammeter (particularly one of such a reputable make) could give "wildly inaccurate readings". Are you sure that it wasn't being confused by something other than DC?
