Hi all
this is my first post on this site i hope i can be as much help to everyone else as much as you will be a great help to me.
First project i need help with is my garage roof, its roughly 2.7m wide by 5.2m long, its a felt roof at the minute and its leaking like a sieve! the felt is not worth repairing and the roof trusses are rotten so the whole lot needs taking off and starting again from scratch.
The way that the roof currently is constructed is that the right hand side wall as if your looking at it from the front is slightly higher than the left, each roof truss sits in a gap inbetween the bricks instead of sitting on top of the brick work, they are spaced about 371mm apart so i have 14 trusses through the length of the building and have firings nailed to the top of the trusses that give the fall of the roof for the rain water to run off.
My questions to you guys are first of all does it matter that the roof sits in gaps in the brick work instead of ontop of the bricks as on most of the tutorials or pictures iv seen it tells you to sit the trusses on a board that runs ontop of the brickwork?
What material would be best to go ontop of the roof to finish it off and make it water proof, iv been told felt and Fiberglas as very much out of date is there some sort of sheet material that would be good what do you guys recommend? and how do you go about fitting that particular type of material you recommend?
around the sides of the roof where the fascia boards bolt to the roof trusses do you want any overhang the other side of the brick work from the trusses of make them flush with the wall? and along with the fascia boards is there anything else i should be doing to help waterproof around the sides where the fascia boards sit?
what would be the best way to attach the roof trusses to the rest of the building, iv been told that wall plate strips are the best way to ensure the roof trusses are attached to the brickwork effectively is this correct? also in the garage at the minute the garage roof is only attached with about 4 of these wall plate strips two at the front and two at the back, is it worth putting these wall plate strips on every roof truss or can you do a smaller amount of them spaced out?
What weatherproofing paint would be best to treat the roof trusses with as they are currently untreated and sitting against brick it would be better for them to be treated?
I really do appreciate any advice i get
I look forward to hearing from you all
Cheers
Ben
Cheers
Ben
