Lower Intercom Volume
23 Jan 2017
My flat has this old style intercom system with a very loud 'buzz' when someone presses the flat button outside the communal area.
Can I somehow lower the volume? I am pretty sure the buzz comes from the handset speaker, therefore would it be possible to add a volume controller to the yellow/green wire?
http://imgur.com/a/ARUWu
That's a bell system 801 handset the newer ones are tone generated via the speaker , there should be a jumper inside the handset base for high or low .
You are correct, it's 801 however I cant seem to find the jumper for High/Low?
Can you please show me in the attached pictures?
also what is the thin metal tap type switch to left of where the 801 is written?
http://imgur.com/a/Nly5W
Looks like you have an older version that does not have the jumper , it's normally to the left of the receiver switch ...
even their own brochure says that "The telephone has two levels for the ringing tone. A HI or LO position can be set within the telephone on installation or at future date." for all the three types of models..weird.
so what could I do about this nuisance buzz volume? would my plan (in original post) work?
OR.. I could just order a new 801PS model, but I would like to do some DIY and put a small toggle switch in myself if I could get some guidance :-)
