Would be really grateful if someone could advise us as best they can regarding our radiator issues.
The previous house owner installed 3 new radiators in the kitchen but they barely heat up. If 10 is max power, I'd say we achieve 3.
We have British Gas Homecare so have had them out on numerous ocassions with no success. They have tried re-balancing the system to direct more flow downstairs and fitting a new pump to the boiler but this made little difference. They are not sure of the exact issue but feel it would be best if we do a powerflush.
We decided to contact a local plumbing company to get their opinion and they feel a powerflush is not needed. They advised that it is likely that the new radiators do not have a direct feed from the boiler (all the pipework is hidden in the walls), but that they are probably using a feed from elsewhere and that this is not sufficient to heat them up.
We agreed on a solution - to install new pipework from the boiler to the 3 radiators in the kitchen. Anyway, the company sent someone out and he advised he was going to look for a blockage rather than fit new pipework. He couldn't locate a blockage, but he found a network of pipes on the first floor that was feeding the kitchen radiators (on drops) and the pipe feeding the downstairs radiators was a very narrow pipe going into a wider pipe. He re-routed the wider pipe to another wider pipe hoping this would fix the problem.
It seemed mildly better for an hour or so then all the downstairs radiators (except the hallway) were stone cold. I contacted the plumbing company and they advised we have 2 options - take up the bathroom tiles so they can see where the pipes go (??) or run new pipework from the boiler to the kitchen radiators (our original agreement)!
Sorry this is so lengthy. If anyone can offer any insight it would be much appreciated.
Aco
Aco
