D
Doggit
Now that's classy Shambolic, I'm not often envious of others, but I'll admit to it here. So what time does the normal system come on then for the rads, and what's your design and setup.
I'll go into it tomorrow too late tonight as working early.Now that's classy Shambolic, I'm not often envious of others, but I'll admit to it here. So what time does the normal system come on then for the rads, and what's your design and setup.
With new builds designed with so much vertical and horizontal open plan under floor heating might be the best ( or least bad ) option for silent heating. The architects I know would if they did such a building would include some air management to bring warm air accumulating at the top of the building back down to the ground floor level. This reduces the likely hood of Warm lounge, bake house bedroomsSo bennyboy tell me how rads will heat my lounge evenly?
2.5 storey height and over several rooms?
Go on tell me?
Standard rads might look out of place, ther are rads that do not look like rads. and then there is the Warm Wall concept.Rads would look crap and leave massive cold spots.
suppose there is an un-expected change in your daily routine and you need the house warm at say 5 am. How quickly will the UHF get the room to a warm temperature on a cold winters day ?So my underfloor has built in optimum start and I set it for 20 deg at 630am.
Sarcasm, the lowest form of wit, and a tool used to deride the opponent in a debate.Nurse has took Bennys internet privileges away again as he's gone.
Google is fine for almost instantly locating public domain documents. It takes a while to obtain the more interesting information as most of it is sourced by questions and answers by e-mailI think Google have rationed him
Isn't that the temperature that the house is kept at when it not required to be warm ?What is the set back temp?
