- Joined
- 27 Jan 2008
- Messages
- 28,438
- Reaction score
- 3,456
- Location
- Country
I have found a few times where energy has been used, which the user was unaware of a fault causing the extra power to be used. I have had a freezer dropping temperature to -25°C instead of -18°C and I found out because of using an energy meter, I also trimmed the heater to make my beer to correct size so it did not over shoot using an energy meter.
However I can't see how a meter measuring the total a house used can ever produce information which can actually help, I would however be interested to see over a period of time how much is used with lights, how much is used with a cooker, and other items where you can't use a simple plug in unit.
Where items use a mark/space system to control the power used, be it an electric hob, and oven, or where you have many user options it is hard to compare devices or work out which is the best method, if I use a low heat to wash cloths then I also use special soaps, and longer cycle, I tried to compare what the machine used with each cycle, however I never got the same results for same cycle twice. It seems my washing machine measures the weight of the washing and adjusts the water used, so even with a single item it is hard to work out what it uses, so it must be impossible when the measuring device does the whole house.
At least with current transformers which measure current and time, you can select what circuits it measures, I have wondered if there is a way to monitor how much energy each room needs to keep warm? I have tried to control rooms independent of each other, however even with heating turned completely off in a room I find the temperature will rarely drop even 4°C lower than rest of the house, although we have insulation to stop heat going outside, there is very little stopping heat going from room to room.
So theory may say using eTRV's in every room so living rooms not heated at night, and bedrooms not heated in the day, you should save energy, in real terms the rooms don't seem to cool that much.
