You don't need to buy a Felder! Simplest approach to make a
housing (
dado is an American term
) is probably a 1/2in router and a home-made T-square, especially if the timber matches the diameter of a particular cutter (cutters are available from 2mm to 22mm or more in 1mm increments):
Above: This is where you want to cut a housing
Below: A simple jig to guide the router can be made using a piece of 18mm plywood or MDF and a piece of 2 x 1in PAR softwood as the fence.
In this instance the material would be clamped onto the bench and overhang it slightly to accommodate the extra thickness of the fence (22mm softwood onto 18mm MDF). The material is clamped onto the bench and the jig is clamped or screwed onto the material (if it is MDF the holes can be filled and sanded later). The base of the router runs against the T-square "blade" and the housing is ideally worked in multiple passes increasing the depth each time. The fence will end up with a notch cut-out by the router cutter:
This notch can subsequently be used to align the fence to where the grooves are required:
A plus of using a router and a jig is that with appropriate stops (or pencil mare and careful routing) stopped housings can be cut (all but impossible to achieve with a table saw)
This is one way you achieve that set-back shelf look which is seen in much professionally-made furniture and is far more stylish IMHO
To fit that way the front corners of the shelves are notched (jigsaw and chisel) and the shelves are slid in from the rear.
There are other techniques which allow a more precise fit, where an exact size cutter isn't available, but the approach shown above is doable on a construction site, cheap and fast (and it doesn't require £5k to £10k of Felder, either, or even £1k of cast-iron table saw)
As Vinn so rightly says, edge rebates can be easily handled by a bearing rebate cutter in a hand-held router, or even by a plain straight cutter and a side fence - so not even a router table is required (and in any case, I'd be hard pushed to want to make one on site!)
Personally I don't much care for stacked dado sets (on table saws), having used them professionally in the past. It's worth bearing in mind that they can't really be made to work well on a lightweight table saw or site saw (e.g. my own DW745) without adding considerably to the risks taken by the operator (namely me) and that they require the user to manufacture special guarding for safe use - and we all know what people do with guarding.
