That's an auto bypass.You mean this fellow? If so I have no idea what so ever! Please enlighten me!
Yes.That's an auto bypass.................
Is it ?
Its a flow setter, not what your looking for, any chance of a pic of the hot water cylinder and pipework ?
Yes.
Look at where it is.....Hmmmmmmmm
The airing cupboard is an interesting place... you are looking at two hot water tanks that are heated from the gas boiler, and also from solar panels. But with electric heating back up. The filling loop in the picture is connected to the second hot water tank.
Will do tomorrow!
That silver braided hose is your filling loop.
Connects near the the gauge
valve on the back wall
That's a bg install.
Check airing cupboard and loft where cistern used to be![]()
It's connected to the hot water primaries/coil.So how does it work? How does water passing into a hot water cylinder via the fillong loop (or vice versa) find its way into the radiators to replace the missing water? I thought the water in the radiators was separate. Sorry if being dumb.
