When the 2 blue valves shut it allows the pump to remove heat from the boilerSo what does the auto bypass do?
Its not an automatic bypass, its expensive gate valve the way its been usedit should be used for balancing but it looks like it was just set to pass (a fixed flow) back to the return.
That's British gas for you.Hardly surprising as they are not doing the job they were designed for .
So how does it work? How does water passing into a hot water cylinder via the fillong loop (or vice versa) find its way into the radiators to replace the missing water? I thought the water in the radiators was separate. Sorry
It's connected to the hot water primaries/coil.
That is the same as what's in the rads, not the same as what comes out the taps.
Open the black valve at the end of the silver hose.
I can't see in the picture but it may have a valve at either end.
There a gauge there too.
Fill it to about 1 bar bleed all the rads and re check the pressure.
weight of water in upstairs radiators,pipework is creating a force on the downstairs gauge.The other thing I have noted is that the pressure gauge in the airing cupboard (upstairs) is a 0 bar and the one in the boiler room (downstairs) is around 0.1 to 0.2 bar. Why would they be different?
The airing cupboard is an interesting place... you are looking at two hot water tanks that are heated from the gas boiler, and also from solar panels. But with electric heating back up. The filling loop in the picture is connected to the second hot water tank.
