I have an ECOtec Plus 831 that has just stopped working..
Basically, the boiler pump starts running and the radiator sign appears with the pump running sign in the window but the boiler won't fire.
There is an initial whir of the fan as it tries to fire up but then just cycles back through the same scenario repeatedly. same for the water water, the tap sign appears and does the same thing with the fan then goes through the process again without firing up.
Anyone have any ideas what the problem is?
There are no error codes displayed and you can see (and hear) the diverter valve moving in and out with these cycles.
The system is clean and loaded with x100 & x200
Regards
Regards
