Personally I think there is the potential for interstitial condensation
moisture could form on the gap-facing surface
condensation is a risk based on humidity and temperature difference
You do not know what you are talking about, woody. So stop pretending you do.How does moisture (ie condensation) form on the surface of a porous material?
Obviously glass is an extreme case for permeability and I was using that example purely to correct the assumption that it was cold air hitting warm surfaces that cause condemnation.Can you extrapolate that in to what actually happens to atmospheric moisture in this type of situation within a wall?
You seem to be applying the bog standard "air condensing on a cold piece of glass in a room" scenario to completely different situation.
In particualr with "risk" analysis, there are the variables of not only what may occur and to what extent, but the consequences of any occurance too.
Note - every single wall of a house has moisture in it.
