Hi All,
The Fascia on my garage is wood and fairly rotten. so I thought I would replace it with uPVC, I intend to remove the guttering, remove the rotten wood and replace with solid uPVC. The existing Fascia is 20mm thick and 150mm height, there are 2 sections, 1 back 1 front.
Access is limited as it is very close to the people that back onto the garage and they have plants, also the Garage roof is corrugated Asbestos, so I won't be climbing on that, There is just about enough room for me to get down there with a ladder.
I don't think that I'll have too much problem removing the gutter, I think the first problem is going to be removing the existing wood Fascia, although it's fairly rotten, I think most of the rot is at the bottom of the fascia, so how do I know where it is screwed \ Nailed to the garage? I'm fairly convinced that it's attached to the brick garage, the 'Beams' don't go through the garage the end in the garage.
Second problem, how do I attach the uPVC fascia, I'm going to go for solid plastic uPVC, I think that you can get some that is foam filled, but I did like the Idea of that, so I just put raw plugs in the garage wall and attach to them?
Third problem, fitting the guttering, I intend to replace the guttering, but with limited access I wasn't sure the best way to do that, I did think, do I put up the uPVC Fascia and mark out as many brackets as possible, take it down and fit brackets?
How often do I need brackets? The garage is 6m long, so I was thinking 10 brackets evenly placed if possible, dose that sound OK?
I have seen the foam corrugated infill's but not sure weather to bother, they're not cheap.
Sorry for all the questions, but first time I've done anything like this and I'm a fairly general DIY person.
Many Thanks
Steve
Many Thanks
Steve
