- Joined
- 4 Mar 2017
- Messages
- 51
- Reaction score
- 1
- Country
Hi Folks,
I am about to embark on a major renovation of a bungalow we have just bought. Current size is around 1000sqf and we are extending to around 1500sqf.
We will be re-plumbing, rewiring and installing a new combi gas central heating system with all new pipework.
I will be getting a builder in to do the extension and some of the renovation, but I want to do some of the basic work myself – such as installing radiators and pipework (even if I don’t connect it all up.
I and a reasonable competent DIYer and have done some plumbing before – though no design work on central heating.
More importantly I want to know how everything works and to know enough to be able to have intelligent conversations with the professionals to allow me communicate exactly what I want in their language, but to ensure I get what I want.
So I have been think about the design of the CH and hot water systems.
I am thinking about a Worchester Bosch Greenstar CDi Classic 42CDi .
I will need 12 radiators (two of which will be chrome towel rail types in the bathroom and en-suite)
This seems to work out around 63,000 BTUs or 19kW needed. The boiler produces 30kW – is over speccing like this OK?
What I am planning for the CH pipework is as follows –
22mm Copper connection to the boiler for flow and return for 1m (WB say at least 600mm copper). Then using Hep2O for the rest.
I will have an automatic bypass valve between the flow and return near the boiler – I am thinking of using a tee where the copper meets the plastic pipe.
I will have two zones (7 radiators in one and 5 in the other). I plan to split the 22mm flow and return and run closish to each radiator. I will take a 15mm branch from the main 22mm flow and return for each radiator (so each 15mm branch will feed only one radiator).
I plan to insulate all the pipes with 25mm thickness insulation
As far and how water is concerned, the boiler has a 15mm outlet so I guess I use 15mm Hep2O all the way. I need to service hot taps in kitchen, bathroom, en-suite and utility; two showers. I think the washing machine and dish washer take only cold.
I know there are very detailed calculations that can be carries out on flow rates and heat loss – is this really necessary?
Have I given enough information to allow an assessment of whether this will work? If not, what other information do I need to work out or provide?
Sorry for all the questions.
