I'm replacing the carpets on ground floor with laminates and while I'm doing it I want to lay some speaker cables and HDMI cable in the living room. It's concrete floor so I'm looking to dig a channel then place a plastic pipe and seal again with cement. This way I can also pull out and change at later time if required.
Is SDS drill with chisel the right tool to do this job? any recommendations on the drill for under £100?
Edit:
One more question, is the SDS drill accurate? I'm also looking to do some wood work involving to drill holes for dowels, I have a simple handhold dowel jig so just wondering if the SDS drill at rotary mode is accurate and dont vibrate much to suit this job?
Edit:
