Hob is 7.4kW, 32A
A John Lewis induction hob which is made by Electrolux/AEG. It doesn't not come with the short flex heat resistant cable from the cable outlet box to the hob - 90C. I see TLC do a 4mm heat resistant cable available by the metre as well. It is rated at 35A. This is pushing it a little, although the cable will only be around 0.5m in length.
https://www.tlc-direct.co.uk/Products/CA4TQ3slash50.html
Does anyone know who supplies 6mm flex heat resistant cable? It seems to be rare stuff.
Or, do most of you fellas fit the 4mm heat resistant cable for the last 0.5m? It is within range.
