Elite 24 with Exodus smokes
10 Jul 2017
Hi All,
New to DIYNOT so Hi to all
I've just installed an elite 24 and everything working fine apart from the smokes in unset mode, they don't set the speakers in the rkp off when in unset mode yet when set everything works fine, can anyone help please.
cheers in advance
You can change the exit mode to be a timed exit so that the system sets after a preset time period if thats what you mean? But you will have to enter via a zone programmed as entry/exit if full set unless keypad is outside of the protected area. All of this is not recommended though.
cheers,
I dont want to do anything that compromises security, however I have a keypad in my bedroom also and could set from there hoever it doesnt set unless i exit a zone, can you advise
cheer
Are you selecting Part Arm when setting from upstairs keypad? I guess your doing a night setting? If so you can enter code/fob and press part yes or scroll down until keypad says part arm then press yes. Or enable quick arm in keypad setup and just press the part arm button only. What zone is the keypad saying to exit via? Also in Area options you can make part arm instant which you can use as you have a keypad upstairs.
Every zone could be armed at night, the same as when vacant, as I have perimeter protection vibs on all doors and windows and vib contact on back and front doors as well as pir's down stairs, so i'd like full set if possible
Yeah but full set the system thinks your going out & its waiting for a final exit zone to open then close.
Your need to use the part set option, this can then be silent with a bleep once set whereas the full set makes a continuous entry exit tone.
thanks
do i set this up on the keypad or can it be completed via wintex
Either way you like, if your not isolating any circuits at night time then nothing really needs to change. Maybe use the quick arm feature in keypad set up. And in area options make part arm instant & part arm silent (has a bleep once set)
Then on upstairs keypad just press the part button or if its s newer keypad its the button with man in house. This should then arm for night time. In morning your need to remember to disarm. Or programme the landing PIR or Hall PIR as guard access this will then give you a reminder bleep in the morning if you forget to disarm.
all looks sorted thanks for your help
