- Joined
- 20 Aug 2017
- Messages
- 26
- Reaction score
- 0
- Country
I've been trying to fix my Linea 24 because the central heating wasn't working. After trying different things I pull off the diverter motor and the hot water started running through the central heating. I've now ordered a new motor and I can see it working whereas the other one wasn't. However for some reason I'm not getting any CH still! I've tried the trick of pulling off the diverter motor but still no joy now.
The odd thing is is that when I turn on the hot tap then I will get hot water out for a bit but then the boiler will make a sound like a kettle cooking and then the pressure will drop and the boiler will go off with a 02 (Overheat) warning. I restore the pressure and try again and the same thing happens. The hot water was working fine until I changed the diverter value, does anyone have a clue what is going on?
Many thanks,
Anthony.
Many thanks,
Anthony.
