I'm struggling to get a good start with a project I'd like completing.
I've spoken with a builder who looked at the project and gave a few ideas but suggested that I get an architect / structural engineer to work out the best solution first then they could quote properly.
I contacted a few companies but have had what I consider to be very high quotes (perhaps that is just me!).
Anyway - what I'm after is as follows:
Our bedroom is 4m x 4m and sits above our garage which is 7m x 4m. Our bedroom was added as an extension about 25 years ago. Our bedroom sits level with the garage at the front and has a short roof at the front, then a long sloping roof at the back which goes all the way down to the single storey rear.
We therefore have a bit of a sloped ceiling on the back edge of our bedroom and then a wall. The wall has a short door in it to access the space behind which we use for storage.
We want to put a dormer window in this space to create an extra small room of about 2m x 2m to give us an en-suite. The floor in this space is identical to the rest of the bedroom with the same joists running at the same gap (400mm)
So I'm a bit confused as to where to start, I thought a builder was the correct place but as I would like quotes from a few, the builder pointed out they need to know what to quote for. So I need to sort out the planning side.
I'm 99% sure from reading the planning website that it won't require planning permission. I take it, that it would be just adding a dormer and wouldn't be counted as a loft conversion?
I realise that I would need building regs - what sort of cost should this be?
I need a structural engineer to work out how to move a roof beam which will be in my way.
And I think I need an architect to draw up plans for the builder to work from which will comply with building regs.
I know it varies a little from area to area, but how much should this kind of work cost? I've had a variety of quotes which all seem high and to be honest they aren't clear if they cover everything I need or not. Is the above everything I should need before I get the builders to quote?
I wanted to fit the bathroom myself - so really just want the dormer itself building (including having the beam removed or altered), the window fitting, major plumbing works done, electrics done and then left for me to fit a shower, toilet, sink, flooring and to tile the walls.
