grease on screws
14 Jul 2016
The aim is to have screws/bolts that can be easily unscrewed in say, 10, 15, 20 years time. Say those securing a sink. What sort of grease would many recommend? Obviously grease that does not harden up of course.
thanks
I'd use copper grease for that. Also the right combination of steel/stainless/brass etc can make a difference, but I'd have to look up what's good and what's bad. I've taken apart some very old equipment full of brass screws and they come out great.
Watch that you don't use disimilar metals where they might corrode. If it's wet conditions under a sink I'd use stainless screws
Also not sure what you mean by harden up. Even thread lock doesn't get so hard that you can't unseal it.
for stainless, use Nickel grease.
It is sold in expensive tubs for boats, but a tube or mini-tin will last a lifetime. It is also useful in Aluminium, which reacts badly to copper.
It's the only grease I've come across that is recommended for stainless screwed into ally.
Type 42 Destroyers used to have a severe problem with dissimilar metals. Whatever was screwed to the deck made the deck-holes corrode, starting the day they were built. They're all scrap now, apart from one the Argies bought.
