- Joined
- 1 May 2016
- Messages
- 44
- Reaction score
- 0
- Country
I'm fairly new to DIY and usually just fork out money to people better at it than me, however having just moved house i'm pretty skint and am looking to do some of the work myself. Our living room was pretty garish and we stripped the wallpaper off that and the hall/stairs but it's left some pretty unsightly cracks and bumps which will show through any paint and I'd prefer not to hang paper everywhere. So i guess I have a number of questions (please be gentle)
Thanks in advance
- Is a skim coat the best solution? The walls aren't falling apart, but they're not even so i'm hoping adding a skim coat will give me a paintable/wallpaperable surface
- What kind of joint compound would be best for me to use?
- Do i need to seal/prime the wall (bare plaster) before i skim or after? or both?
- I've done a lot of research and believe these are the tools I need. any advice?
- 12" taping knife
- 6" joint knife
- 13" mud pan
- pole sander
- how do you skim tight into the corners? there are very small gaps where the ceiling meets the wall...do you skim tight into the gaps?
- The ceiling was wallpapered too...so that's come off..do i use the same compound for the ceiling as I do the walls?
- Also the corners of the chimney breast are rounded so i was going to use some corner bead to "square it off" but should i could stick it on with the compound or screw it in?
- Any other tips?
Thanks in advance
