- Joined
- 31 Mar 2013
- Messages
- 559
- Reaction score
- 56
- Country
A mains-pressure cylinder was similar but added annual servicing costs beyond the gas boiler service.
Don't you just love manufacturer snake oil.
if you did you would already know the answer
This means an emergency closure of the village High Street, a busy through route, is un-avoidable.
Informally one of the Cadent people mentioned that there are many similar locations around the UK where the increased peak morning demand from new combi boilers running showers is taking the location's gas supply close to if not beyond it's maximum capacity.
Not closed. Single track working under three way traffic light control. Planned over a year in advance and during the school summer holidays.Some people even have roads closed to re thatch their 500 year old cottage.Was that you Bernie ? fess up.
That was a couple of months ago, Replacing covers in the middle of a junction.Bernard,the water company will be next to dig up the streetThey like soft soil
It was stated that the work would be a simple job. Moving the supply pipe feeding a side street from an old small and now inadequate main under the High Street to a less ancient, larger main running under the other side of the High Street.That is pure ballcocks,the mains renewal work is planned works due to ageing pipework
The drivel about fan speeds and gas valves proves that you less than you think.
It is a very large roof over two properties, a bit too much for a DIY job...Were the thatchers on day work ?
nd if you read the cadent press release,there is no mention of combi boilers
When natural gas was proposed in the 1960s, only two meter sizes were standardised on, U6 and U16. 6 cu/m hr (212 cu foot per hr) and 16 cu/m hr. They had many sizes. A U6 was designed to cope with the vast majority of domestic homes. Previously they had 3 cu/m hr (3/4" connections) and 3.75 cu/m hr (250 cu foot per hour). When converting to NG from town gas the distribution system could cope as pressure doubled with pipes already large bore to cope with town gas. The home gas installation pipes were instantly oversized. The CV of the gas was higher as well, able to deliver twice as much heat into a home down the same service pipe. A house was supposed to consume 6 cu/m hr if the need was there. They have cut back on this, skimping, taking an average for a district. A U6 can give approx 62kw of heat.
If there are distribution problems at peak hours, then get a combi with a small water storage vessel integrated, it will help. I know one fitter who fitted 28mm pipe from the meter to the combi and 32mm near the boiler to give internal gas storage when the combi kicked in. It worked - the burner was susceptible to pressure and flow changes. Matters like having 1" x 1" maintaps help a lot as well. It is a matter of attacking all points, until they put in a proper supply as they should have done initially. So a homeowner has to pay extra because the gas distribution people skimped. A 40kW combi in a supply that should be capable of taking 62kW is not even near maximum capacity.
It overhangs the pavement and only gets hit when large badly driven vehicles mount the pavement.and have a very low thatch roof overhanging the public road.
When we built the house on the banks of the Sharn Brook ( the Walter Segal self build ) we were not aware the babbling Sharn Brook could become a raging torrent.if you want to live in a flood plain
bernieits a small world and your neighbour a couple of doors away does nice cakes !
