Ep2002 wiring for a Hive dual
26 Jul 2015
Just wacked off the ep2002 and see quite a fair few wires.
I guess the wires going to the original thermo are now redundant. However.
Is this a case of removing the Alpha wires and just connecting with the ones left as per Hive i instructions?
Ep2002 has a 5 socket which the hive dosnt.
The only redundant wires here will be the ones in the cable going to the room stat, the red live link going to terminal 5 is made inside the Hive so that won't be needed, but the brown wire in terminal 5 will need to connect to L.
The wires in terminal C will need to remain connected together. It looks like the yellow wire in B is coming from your room stat, If that is the case then the black wire from B will need to be connected to the heating on terminal of the hive. The terminals on the Hive are not really designed for more than 2 wires so I'd recommend using a connector to join all the L wires and then run a single wire to the Hive.
B is neutral (Two black one blue)?
What one do i put C in too?
Wow, got it working mate. Connected original B and C together on hive and working!
thanks for the help.
um, spoke to soon, some weird behaviour going on with boiler it turns on when I press on the thermo button, but i need to reset the boiler.
im now knackered so will look tomorrow.
