My son's bedroom suffers from condensation on the walls behind his bed. The house his a 1920's semi and has virtually no cavity and we've been advised it's not worth filling.
His bedroom is at the corner so has two external walls - one north facing and the other west. His bed his on the external wall and we get condensation building on the wall behind the bed due to lack of air flow.
My plan is to insulate the two walls but as the room is tiny, I need the best option whilst losing as little space as possible. So far, I'm thinking of the following options:
1. Line walls with wallrock lining
2. Found a product called aerotherm which looks good and is only 1mm thick - I'm not conviced though.
3. Strip walls back to brick and put up insulated plasterboard or celotex with p/board on top (I'd only be able to go to 25mm insulation max plus 12.5mm plasterboard due to needing to fit a bed in.
Any thoughts or other suggestions would be appreciated.
Thanks,
Rob
Thanks,
Rob
