I can't remember where I heard it or when but I have always thought the label was not reqired in the cut out and meter box.As I've said, same here.
Agreed. However, since you've never seen one attached to an earth block, you presumably are one of those who has never fitted them. If you believe that is non-compliant with the regulations, why did you not attach labels? (just because "no-one else does"?)
Other than that, I have to say I was not aware of the regulation - or maybe your interpretation is correct.
Why, then not require it in a DB/CU?
