- Joined
- 7 Mar 2004
- Messages
- 300
- Reaction score
- 4
- Country
Can anyone tell me what the following radiator valve fitting is?
Thanks for the replies
I did suspect it was something like that but assumed it wasn’t as it doesn’t look like there’s much to attach a hose to. I wouldn’t like to drain more than the one radiator with it.
Unfortunately, it’s an upstairs radiator and there doesn’t seem to be any drain-off for any of the downstairs radiators. Two were removed at some point so I’m guessing one of them may have originally had a drain-off.
I need to drain the system due to an issue with a towel radiator valve so I’ll fit a proper drain-off then.
You can get self tapping drain off cocks. Just screw into the pipe then drain and it seals reasonably well round the pipe.I need to drain the system due to an issue with a towel radiator valve so I’ll fit a proper drain-off then.
Thanks - I've bought one of those and there's a YouTube video of a guy demonstrating how to use one. It's a bit ugly though so I agree that replacing it with something a bit nicer is the way to go.
It's an open vented system (cylinder in the bathroom and two tanks in the loft) but I don't feel confident (experienced enough) about relying on a vacuum - the worse case scenario always applies when I'm doing anythingIs it a sealed or open vented system?
If former then vacuum in pipework may allow you to change valve without full drain down. If latter then you could put a bung in the feed pipe from the F&E and one in the vent pipe to seal the system and create a vacuum - but don’t forget to remove the bungs after.
They are solid floors but that's interesting - how would I tee off through the wall? The house is a really odd example with two rooms having a lower floor than the rest of the house. Unfortunately, none of them are near a door so it's difficult to decide where to place the drain cock - but your suggestion to go through the wall hadn't occurred to me. Is there some kind of fitting I could place on the outside wall as a drain cock for the CH system that wouldn't freeze or fail?Better still... get under the floor and run a drain off pipe from a rad feed to outside and fit a drain cock there. If floors are solid then just tee off through wall to outside.
