Keep on plugging Blowhardgreen. You might get there one day.
I wonder if that was an electric immersion heater. About one tenth the power of a modern gas boiler.
The other side of the coin, is that in the winter, it (virtually) cost nothing to supply the hot water. Swings and roundabouts.
Add a Combisave to the boiler outlet, and that'll cut down on wasted water whilst the combi gets going.
There's no question, I did balls up on that one. So you don't rate the combisaves then Dan,
The better ones use past usage to intelligently time
In that case turn it around, put a physically smaller heat source radiator in, more efficient and controllable, gain the other half of the airing cupboard back, and gain massive brownie points!Is your hot water tank in the Airing Cupboard? Is SWMBO prepared to lose it ('cause with the heat source for the airing cupboard gone will the SWMBO be happy)?
Big brother boilers taking control of the heating and hot water. Is that really a better way to run you heating and hot water. Or is it a sales gimmick for the un-aware and easily mislead customers.
i assume you're taking the Mick,
Also why would a cluster of boilers need to interconnect with each other and exchange data between themselves. Yes I can see some "advantage" in a faulty boiler being able to call the service man without involving the people in the house. Ideal for landlords who have tenants who do not look after his property but for owner occupiers ?, is it necessary.
Such as the algorythm and test methods that can make a boiler more than 120% (hi) efficient when the actual efficiency is often far lower.
You can't do gravity on a new boiler, has to be fully pumped. With clean pipe work there's no problem with recovery time on a decent cylinder.It was the main reason we went for a combi rather than replacing like for like and keeping the gravity.
