Hopefully simple, but need to turn off a 'tap'
23 Jan 2013
Kent
I need to be able to turn off a 'tap' - might not be called that though!
Any suggestions - probably simple, but I'm not an expert in these matters.
Thanks!
The small square nut at bottom turns anticlockwise in the position, and will shut it off.
Edit: you may need to push it back up if it's dropped down off the thread.
Is this part of your building demolition project ? I hope you're not on a meter;)
This guy is demolishing something and cannot turn a tap off. Good grief he must be a "tradesman."
