So the problem is that I have a 30-year-old laminate floor in my hall, and a couple of sections at the edge were badly damaged by the previous owner, so I’ve managed to chop them out for replacement.
I couldn’t do it any other way, as far as I can figure out, for a couple of reasons – (a) this kind isn't available any more (all different sizes and thicknesses now); (b) it was installed when the house was being built, so is under the skirting boards.
Anyway, I managed to chisel two damaged pieces out quite neatly, scrounged a bit which is nearly the right thickness, and cut it to size. When I set the 2 new pieces in, I was pretty satisfied with the result.
So… I vacuumed the concrete floor, washed, let dry, applied No More Nails the next day – put the laminate pieces in position, and piled bricks on top. Over 24 hours later, sadly I was able to lift the pieces out again. The NMN hadn’t stuck to the concrete at all, and was still quite easy to scrape off the bottom of the laminate.
So I guess it’s not suitable for this kind of application – what would you suggest? Would silicone be any good? Tile adhesive?
Thanks all
PS I know laminate shouldn't normally stuck down, but the interleave bits are completely different on the new piece, and I can't see any other way...
Thanks all
