I have fitted a ariston 15litre unvented water heater in an airing cupboard. A shower feed is situated fairly close to the unit, so I am opting to use the full range of expansion controls. Pressure reducing valve, Non return valve, expansion vessel, pressure relief valve, and tundish.
What I want to know is; Is it absolutely necessary for the prv to discharge through copper pipe?
The plastic overflow that is existing drops 1 meter straight down, then a shallow fall for another 2 meters where it connects to the kitchen waste outlet pipe The fitting guide says this pipe should be metal, but its going to be a problem getting a new pipe back to the kitchen or to an outside wall.
