I have a 2012 Vaillant Ecotec Plus 837 which is now outside the extended guarantee period. It has developed the F28 fault. The electrode sparks but no flame, after many resets, still no joy. The plumber tested the gas pressure on the inlet valve and after checking it, it fired up. A few days later it stopped working again and he attached his u-gauge on the gas valve and it fired up again!
Had National Grid out who confirmed the pressure at meter was 21mb and dropped to 20.5mb with heating demand from boiler. Had a gas engineer out who said it needs a new gas valve, got a second opinion from another engineer who stated it is probably the PCB.
Having gone through the menus its also displaying S.98 faulty temperature return sensor.
My options, it seems are as follows:
1. Get the gas valve replaced
2. Get the PCB checked first
3. Get the NTC thermistor replaced.
My question is, would a faulty NTC thermistor prevent the PCB from opening the gas valve?
Or would the faulty gas valve or PCB cause the S98 fault. I would rather get the cheaper parts replaced before going for the PCB or gas valve.
Also how much would it cost to get someone for a fixed cost repair around the Midlands, recommendations appreciated.
