- Joined
- 11 Jan 2004
- Messages
- 46,712
- Reaction score
- 3,927
- Country
Cars like Metro were taken out of production because they could not update them to meet new standards.
I think that mine (a 1959 Triumph Herald) very much pre-dated the Metro!Cars like Metro were taken out of production because they could not update them to meet new standards.
Quite so. Indeed, in some senses, even the 'safest' of cars is still 'dangerous', since it has the ability to result in injury or death.All cars are potentially dangerous and so is electricity.![]()
John originally wrote:
"I would hope that any electrician finding an installation (or part of an installation) that he/she felt represented a serious danger would do everything they could to dissuade the owner of the installation not to use it (or parts of it) until it was remedied".
I suppose that would apply whether or not a CU was to be changed.
Well, first of all we have to recognise the possibility of the existence of issues which have existed for years and have been dangerous all that time. Surely it is possible for checks to throw up the existence of problems which are dangerous whether or not a new CU is installed?
No, it's much simpler and more definitive than that.I suppose it's the age-old question of what is meant by 'dangerous' and 'safe' (or 'safer').
I can't read his mind.I just wondered what sort of problem he (and you) had in mind.
You say "... is not an option" but, at risk of repeating myself, the issue is that, whatever common sense or even 'morality' might say, I am not aware of any authority an electrician has to "lock off" or "disconnect" an electrical installation without the consent of the owner of that installation. All they can do is 'advise' - and if they take it upon themselves to do remedial work 'to make an installation safe' without the agreement/instruction of the owner, they cannot expect to necessarily be paid for that 'unsolicited' work.Back to main question, if you find some thing is dangerous, can you leave it in that condition, my answer is no. So the whole idea of walking away from a job because the installation is dangerous is not an option. You have to make it safe, even if that is simple locking off or disconnecting.
Moral authority.whatever common sense or even 'morality' might say, I am not aware of any authority an electrician has to "lock off" or "disconnect" an electrical installation without the consent of the owner of that installation.
Are you saying that, because they could not be updated to meet subsequent standards, they should be described as 'dangerous'?
That's the point - you're making a comparative point - i.e. saying that it was 'less safe' than a modern car. However, back in the 60s, no-one would have dreamed of saying that my car was 'dangerous' by virtue of inadequacies of the standards to which it had been designed and built, would they?I think so, yes, in comparison with a modern car.
Fair enough, but I rather doubt that that authorisation extended to your removing and taking away the service fuse, did it?In the old days of Norweb, I (along with other "approved" electricians, had authority to cut seals to do board changes.
Exactly, and that's what I've been saying all along. If one undertakes adequate I&T before changing the CU then, as you say, one can give the the customer that advice (or ultimatum), so that it becomes their choice.A simple 'That circuit is faulty and I am not prepared to connect it to the new CU that I install' is all it needs. That way the customer has the choice of getting a new CU but without the faulty circuits wired in or not having a new CU fitted by you.
