Filter coffee pot getting slower, brews less hot coffee than it used to
17 May 2013
I noticed recently my filter coffee pot is taking significantly longer to brew than it used to. Also, the coffee is now not as hot fresh from the pot - I can drink it down right away and it's more warm than hot.
It's a typical one-plate thing, I assume the same heat source heats the plate and the water - does this imply the element is on the way out or is that unlikely? Mine is coming up on 4 years old, when they cost £40 is it worth faffing with?
Only other thing I know can go wrong is scaling, is this a possibility?
Hmm. At 4 years old, that's a tenner a year. Maybe pension it off?
I don't think it is worth fixing. Unless you would rather not put another appliance into landfill, or wherever they go.
Heating elements tend to fail completely. It may be a defective thermostat controlling the heating element.
Yeah the cost is less annoying than it going to landfill. Sounds like tossing in a descaler is not likely to achieve anything?
I would run a load of descaler through it
Run the machine through half way then switch it off, allow to cool, then the other half
Repeat and flush with clean water
Descale once a month
