Removing a macerator
22 Mar 2018
I've just moved into a new property and the bathroom has a macerator that takes all the waste water out of it. From there the run is about 8 metres horizontally out to the waste pipe.
I know next to nothing about plumbing but I do know that macerators are an absolute nightmare. As such I'd like to remove it completely. I was just wondering whether this would be feasible or not. Has anyone tried something like this before?
Liam
110mm diameter and a downward slope all the way - see if you have a suitable routing.
But maybe not if the previous owner used a shyte-gobbler
Presumably this is not the main bathroom. Do you want to keep it as a bathroom or convert it to something else? Cupboard is OK. Shower room with no loo is also a possibility.
Personally I’d say that “absolute nightmare” is over-the-top. Just make sure the users are well-trained, i.e. it’s not used by visitors, and resident women are told that unblocking is their job.
In my case, fitting a macerator in a newly created downstairs loo compared to digging up my drive, forming manholes and breaking into the sewer pipe had a cost differential of around £3K so it was a no-brainer.
Liam
Thinking 6m is the max or is that for something else? (Sub stack?).
In my case, fitting a macerator in a newly created downstairs loo compared to digging up my drive, forming manholes and breaking into the sewer pipe had a cost differential of around £3K so it was a no-brainer.[/QUOTE
Until you have the cost of unblocking it a few times.and repairs.
Unfortunately it's the only bathroom in the flat hence why I'm so keen on removing it!
If there is a feasible route for a 110mm pipe, with a fall all the way, then that would be by far, a superior solution. If the macerator has been fitted for convenience of installation previously, if its been fitted as there is no practical route for a 110mm pipe, then I think you may be stuck with it. :cry:
Not sure I've seen it in the regs, but always been an unwritten rule I think. If we get a job in that involves 'loss of toilets' its gets immediate priority.
Thought building regs said every dwelling must have access to bathroom on main drainage.
This is what I was told a long time ago and it makes sense to me as in say somebody converts a large house into flats, what are you going to do if there is a power cut?
(Expecting the usual comedians to appear). :ROFLMAO:
