    Dismiss Notice
Removing a macerator
Discussion in 'Plumbing and Central Heating' started by Liam Pike, 22 Mar 2018.
Tags:
  1. Liam Pike
    Liam Pike
    22 Mar 2018
    7
    Thanks Received:
    Country:
    I've just moved into a new property and the bathroom has a macerator that takes all the waste water out of it. From there the run is about 8 metres horizontally out to the waste pipe.
    I know next to nothing about plumbing but I do know that macerators are an absolute nightmare. As such I'd like to remove it completely. I was just wondering whether this would be feasible or not. Has anyone tried something like this before?
    Liam
  2. Sponsored Links
  3. Jackrae
    Jackrae
    20 Nov 2012
    2,262
    Thanks Received:
    377
    Dumfriesshire
    Country:
    110mm diameter and a downward slope all the way - see if you have a suitable routing.
    But maybe not if the previous owner used a shyte-gobbler
  4. endecotp
    endecotp
    2 Dec 2013
    3,949
    Thanks Received:
    507
    Country:
    Presumably this is not the main bathroom. Do you want to keep it as a bathroom or convert it to something else? Cupboard is OK. Shower room with no loo is also a possibility.
    Personally I’d say that “absolute nightmare” is over-the-top. Just make sure the users are well-trained, i.e. it’s not used by visitors, and resident women are told that unblocking is their job.
    • Thanks Thanks x 1
  5. Mottie
    Mottie
    27 Feb 2017
    19,451
    Thanks Received:
    1,941
    Essexshire
    Country:
    In my case, fitting a macerator in a newly created downstairs loo compared to digging up my drive, forming manholes and breaking into the sewer pipe had a cost differential of around £3K so it was a no-brainer.
    • Thanks Thanks x 1
  6. just pumps
    just pumps
    24 May 2016
    3,059
    Thanks Received:
    517
    Country:
    Thinking 6m is the max or is that for something else? (Sub stack?).
  7. dilalio
    dilalio
    20 Mar 2009
    8,162
    Thanks Received:
    1,357
    Potters Bar
    Country:
    Removing a macerator!
    More fun than putting one in :LOL:
  8.
  9. Liam Pike
    Liam Pike
    22 Mar 2018
    7
    Thanks Received:
    Country:
    Unfortunately it's the only bathroom in the flat hence why I'm so keen on removing it!
  10. Sponsored Links
  11. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,454
    Thanks Received:
    1,757
    Northamptonshire
    Country:
    If there is a feasible route for a 110mm pipe, with a fall all the way, then that would be by far, a superior solution. If the macerator has been fitted for convenience of installation previously, if its been fitted as there is no practical route for a 110mm pipe, then I think you may be stuck with it. :cry:
  12. just pumps
    just pumps
    24 May 2016
    3,059
    Thanks Received:
    517
    Country:
    Thought building regs said every dwelling must have access to bathroom on main drainage.
    • Like Like x 1
  13. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,454
    Thanks Received:
    1,757
    Northamptonshire
    Country:
    Not sure I've seen it in the regs, but always been an unwritten rule I think. If we get a job in that involves 'loss of toilets' its gets immediate priority.
  14. just pumps
    just pumps
    24 May 2016
    3,059
    Thanks Received:
    517
    Country:
    This is what I was told a long time ago and it makes sense to me as in say somebody converts a large house into flats, what are you going to do if there is a power cut?
    (Expecting the usual comedians to appear). :ROFLMAO:
    • Like Like x 1
  15. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,258
    Thanks Received:
    2,051
    Hertfordshire
    Country:
    Sh1t in a bucket!
    :ROFLMAO::ROFLMAO::ROFLMAO:
    Andy
  16. dilalio
    dilalio
    20 Mar 2009
    8,162
    Thanks Received:
    1,357
    Potters Bar
    Country:
    Quite a few HMO’s are occupied by those for who that is the norm and quite accepted in their country of origin :whistle:
    • Like Like x 1
  17. I would find that preferable to a shyte masher in the house
    • Like Like x 1
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
