Moving sink drain in concrete slab
11 Jan 2011
Hertfordshire
Right in the middle of putting up a stud wall to make the cloakroom smaller to create a hallway to the new garage conversion and Mrs sees the lines I've drawn out and says she hopes that's not where the wall's going.
She's worried about not being able to get the sofa in the new living room so of course now I'm worried, the sofa is ordered and if it doesn't get through the hall (a 30" doors width + a bit) I'll never hear the end of it.
However to make the hall wider I'd have to move the sink drain about a foot. I've never dealt with drainage under the slab before.
1. I'm assuming it goes straight down under the DPM?
2. How much of a pain would it be to move?
3. Would I have to make a trench a lot bigger than the distance I want to move it to be able to manipulate the pipe?
4. What sort of fittings are used?
Cheers,
Dan
you need to post some photos,every property is different and if in doubt get a qualified drain installer in.
Oh and ask the Boss first before doing alterations.you know it makes sense :idea:
Not to worry. I've cracked on with the wall in original position now. Lets hope that sofa fits!
Here's a photo of the mess though. She had the cleaner in this morning. :eek:
