I had fun last night trying to drill through bathroom tiles which were thicker than average bathroom tiles. I started off using Bosch multiconstruction bits and even after 30 mins of drilling, I'd made a dent about 3-4mm deep at most.
I went out and bought some cheap set from Screwfix and wished I hadn't:
https://www.screwfix.com/p/glass-drill-bit-set-4-pcs/1598v
The 4mm was too small.
The 5mm worked for a bit and then the tip snapped off.
The 6mm did most of the work but even then, it wouldn't go more than 7-8mm deep. I ended up resorting to the multiconstruction bits again and using the hammer function. Still took time but I managed to get through without cracking the tiles.
I've told the wife I don't want to make any more drill holes in tiles but if I have to, is there a good quality drill bit (preferably a set but I don't mind buying a few pieces to make a set).
