Macerator
1 Jun 2018
I am putting a lodge at the bottom of my garden and will need to put a macerator toilet in, what is the maximum it can be from the main drain?
Have a look at the related threads at the bottom of the post? may assist.
It that fails go to the web sites of the preferred and other devices you have seen and you will get a load of technical info
Ken
Depending on what you are planning to have in the cabin you could use an incinerating toilet.
That's a bit more than a box behind the bog though. More like a mini pump station, probably no reason why it wont shift waste 110m I'd have said.
Stuart, can you can get a fall on the drain at least some distance from the existing drain, towards your proposed lodge?
That is exactly what it is Hugh, Saniflo`s version of a Jung /KSB lifting station. From experience manufactures claimed duty outputs are achieved in ideal situations though. ;)
And how much is one of these units? Gotta be pricey... didn’t look on the linky for costs.
