Low pressure and no hot water after moving radiator
3 Jun 2018
Hi
We removed a radiator in the upstairs bedroom to do some plastering and we will install it a new location later in the summer. We remove all water from the radiator. We couldn't cap off the pipes as we didn't have the right size plugs but planned just to do without central heating, as it is summer, until we could do it. However our water pressure has gone to zero and when we turn the pressure valve I do not hear any water and the dial does not move. I have an Ideal Esprit Eco combi boiler. The boiler is turned off.
I have been moving the blue valve?? Can we still increase the pressure while the heating is off and the radiator pipe not blocked off?
Right - first things first...
That is a terrible install...
Second - have you turned off the radiator valves from the radiator you removed..?.
Yep we did, we are trying to cap off the end of the pipes upstairs now although we seem to have a lost a bolt.
Anyway which valve do I turn to increase the water pressure?
Thank you so much for your help
Which boiler is it..? Take a wide shot of it for me please
Silly question but does the boiler need to be on to adjust the pressure. The black one won't move even when unscrewed
What am i missing...?!
Ok, from your pictures it isnt clear where your filling loop is - if it were muggles would have said (y)
Ignore the black lever.
No - boiler doesnt need to be on for there for be a rise in pressure.
The filling loop will be attached to one of your central heating pipes (flow or return..) to the cold water inlet. You turn the water on at both ends and water will flow into your heating - and pressure will rise - you wabt it between 1 and 1.5 bar.
Its usually in an accessible place... but having had a scan of your pics it isnt in an overly obvious place.
I’ve attached a pic as to how a good install would look - you see the flexible silver pipe...? That’s what you usually see. Follow the pipes down and have a looksee... (y)
Make sure the radiator trv and lockshield are closed... or youre gonna have gush.
