A recipe for not getting what YOU want. Certainly listen to his advice, but get clued up before.Seems I will have to trust the electrician's plan
although I now wonder if down lights our what we need?
I could not agree more!If you want recessed lights then larger ones are a much better bet - 200mm dia and up. Or recessed rectangular LED panels.
"Tommyplug" says it.When we moved into this house there were downlights in every room including the office and workshop.
We spent 4 years avoiding shadows and moving around to get something in the right place to be illuminated.
In the last 2 years every single downlighter has gone and good bl**dy riddance to them.
A non illuminated ceiling is a poorly lit room.
A local hall replaced all their fluo fittings with downlighters in the suspended ceiling, when one walked in there it was like a horror movie. Tables and floors were lit but horrible shadows on peoples faces etc. Bookings dropped dramatically and they were on the verge of going bankrupt. Fluo panels replaced (still in place above ceiling grid - is this typical of lazy electricians?) gradually the bookings returned.
The best way of fairly uniformly illuminating a ceiling is (fairly obviously) by using 'uplights' of one sort or another - a technique I use in several rooms in my house. Even very small (wide angle) light sources can illuminate a lot of ceiling.What you really need is a lighted ceiling with considerable overlap from several sources or "recessed rectangular LED panels", as specified by BAS. ... The best thing would be an evenly illuminated "glowing" ceiling, but that is not yet available.
True.The best way of fairly uniformly illuminating a ceiling is (fairly obviously) by using 'uplights' of one sort or another - a technique I use in several rooms in my house. Even very small (wide angle) light sources can illuminate a lot of ceiling.
What do you mean by 'inefficient'?True. However, "up-lighting" is inefficient.
Needless to say, I understand all that, but these discussions about methods of lighting seem often to major on the desirability of indirect light (i.e. reflected off something).Efficiency is output divided by input times 100%. You knew that didn't you? The input is the lumens out from the uplighter. The output is lumens back from the ceiling.
According to universal-lighting.co.uk Ambient lighting using down lights should be between 1.6m to 2m apart & 0.8m to 1m from the walls.
As has been said, it's ridiculous to talk about number and spacing of downlights without giving details of what sort of lights/lamps/bulbs one is talking about.According to universal-lighting.co.uk Ambient lighting using down lights should be between 1.6m to 2m apart & 0.8m to 1m from the walls. Using the 0.8m & 1.6m I can only get 8 lamps into my kitchen (5675mm X 3370mm). So I have no idea how or why I should need 12 lamps?
