Best way to clean this scummy tap?
29 Sep 2015
The tap in my bathroom looks to be covered in limescale and has been since I moved in. It doesn't look very nice. What is the best way of getting rid of these stains?
Also, should I clean/replace the plastic part inside the tap and how would this be done?
Thank you
Wrap tight in a rag and soak with vinegar , cheap and effective, will need leaving in soak at least 24 hrs with heavy lime scale, don’t allow rag to dry .
go to your local supermarket
ask for directions to the "bathroom cleaners" shelf
pick up a bottle
https://www.tesco.com/groceries/en-GB/products/252675391
Usually it is enough to spray on, wipe off with a rag, rinse, dry. If yours has been neglected you can scrub it with an old toothbrush.
It will also help keep your basin and bath clean.
Have a look at the other cleaning products while you're in.
