Apologies in advance if more information is needed, however I will try and explain as fully as possible my challenge.
I have just moved into a new house - it's 3 years old and is 'eco', as such there is a heat exchanger rather than a boiler and hot water is distributed around all houses via underground piping.
The main water inlet is under the sink in the kitchen and from there it branches off around the house - there is a pressure gauge on the main water inlet which reads around 1.5bar.
Here is where I am a bit confused as in the upstairs and downstairs bathrooms the feed for the sinks seems overly complex, I can see the hot and cold feed come through the wall - however they appear to join together via a valve with a white cap - I've not come across this setup before and am trying to understand how it works.
The reason for the question is that I want to install a downstairs shower and need to understand if I have to replicate this valve arrangement for the shower.
Please ask if you need any more information or would like a picture of the under sink arrangement - and I appreciate any feedback anyone might have.
Edit: Forgot to mention - I took the panel off the Bath upstairs and there is the same valve, when I turn the bath on 2 of the pipes get hot and one remains cold, there is also a mixer shower in the bath but I cannot see the same valve arrangement for the shower.
