Hello,
I've been asked to install an emergency light in the Electric cupboard which should be able to act as a normal light (i.e. switch on/off as required) and also independently when the power is turned off - so that the worker can see what is happening in the cupboard.
I'm trying to figure out what is the best way to install this.
Mains power available:
Switch off - emergency battery should be charged/maintained.
Switch on - mains power should illuminate the light.
Mains power unavailable:
Option 1 - Discharge the battery across the bulb until power is available when the switch position will then dictate bulb operation.
Option 2 - Switch still controls operation of the bulb.
I'm trying to figure out how this can be set up without the battery backfeeding into the consumer unit. Is this even a problem?
Which of the options are the best to opt for or feasible?
At the property I have currently:
- DPDT switch
- LED strip lights
- AC to 12V DC converter (cannot remember precise details, but it is suitable for the LED strips)
- Single LED downlight with battery pack
- Cabling, conduit, etc...
Any advice on how to go about this?
Thanks.
- DPDT switch
- LED strip lights
Thanks.
