It would need to be a very worn cutter for the blade wheel to be at an angle that resulted in a helical groove being impressed along a previously smooth pipe.
It is very common.It just needs a small chip in the blade or even some crud.
As per Dilly, it is poor maintenance, of which I am guilty. Which is why I have 2 in my bag waiting to be stripped and cleaned. Which will probably never happen, as the alternative is about a tenner for a new 15mm one
Lol....He probably does...On his own work!.He’s says it’s fineand that he sees it all the time.
How the he'll you get a pipe cutter to thread like that I don't know time for the bin plumber too you'd be better off using your teeth.Bob
It is very easy, Bof.
The question is WHY you would keep going, once the threading starts?
Indeed.Happened to me loads of times...But never ever thought"oh fek it,,it will be fine".The question is WHY you would keep going, once the threading starts?
It's what lies hidden below the surface that would worry me most.
You've met the wife then?![]()
