Insulation is only removed from this corner as there was a rat problem in attic and was removed from this corner only to inspect for droppign and place baits and check for holes into next door.That is a door, is it a solid door? or an egg cartoon filled? If so then it would not of being strong enough to hold any tank.
Did you remove the insulation or is there none in the loft.
Andy
The door was already up there . The Dyno Rod man who came last week actually seen it and said well put the tank on this . I said would you not remove old tank. He said no we wont go near that !
