Fitting out the House of Pain and have hit a wee problem. The roof is twin ridge and quite low pitch so there's not much headroom up there- water level in the hot water header tank is at most 2m above where the upstairs shower heads will be (showers etc not fitted yet) which I suspect will make for a disappointing shower experience
Currently the heat source (water and radiators) is a woodburner (which, as I understand the regs, precludes pressurised cylinders). Budget won't run to a thermal store big enough to be any use- or rather it will but the payback time is immense and there are some structural implications which aren't going to be cheap.
Question- will a shower pump work well enough (and quietly enough) in these circs or will I regret not biting the bullet now and switching to gas as a heat source (so I can have mains pressure hot water as well as the convenience)?
Mains water pressure is good, 25l/minute at ground level. Most of the house is a building site at the mo so no real disruption to life, mains gas is available.
Ta
Ta
