- Joined
- 7 Jan 2010
- Messages
- 14,545
- Reaction score
- 4,679
- Country
Just turn the boiler stat up, see what happens then. Radiator heat output is calculated with a input temperature of 75-80 degrees, so if your running at 55 you will never get the house warm quickly unless you fit oversized rads.You could also look into weather compensation, this basically involves an outdoor sensor which will adapt the power output from the boiler depending on the outdoor temperature.
